External HDD case Fujitsu MHV2160BT
profile.country.en_NL.title
Carelino
I recently replaced my Fujitsu MHV2160BT (4200) SATA 160GB in my laptop for a WD3200BEKT (7200RPM). So now im looking for a external hdd casing for the Fujitsu MHV2160BT.
You might think its easy BUT Fujitsu has been so smart to make the dimensions HightxWidthXDepth in MM= 12,5x70x100 . Im afraid its impossible to find a casing that fits Fujitsu MHV2160BT. Yet i'm hoping there is and maybe somebody give me a couple of suggestions.
The issue is 12,5 mm Height normally it would be 9 or 9.5 mm.
I know about connector and docking stations (prob wont fit either the docking stations). But if I use that it NOT really portable anymore...
Some help/suggestions would be appreciated. I bet I'm not the only guy with a FujitSHITsu having the same problem. I shure hope there is 1 it will fit in.
Carelino
Well it seems to be impossible.... :slight_frown:
