Fan noise.
luislugo
Fan noise.
I bought a bx197xp and I'm very disapointed. There are several problems. The main one is the fan: in normal conditions it's working all the time, making a lot of noise. With the "maximum battery" option, from the vaio power management, it's turning on and off every five seconds, which is even worst! I'm afraid the problem is with the bios. Any idea will be very wellcome. Thanks.
kee-lo_
Please do not cross post
