I just have reinstaled a clean windows pro,and it works really fast,at first it was a real problem whith sound driver,but I finded a parch and now all works right.
Excuse me by my english (I´m spanish)
best regards
p.d : don´t instal any Norton antivirus ó nortonworks it turns slow
to computer.
Hi sandrini,
Welcome to the Forum,
Thanks for the info
hola,
Explica como lo ahs hecho, donde has encontrado los drivers?
Saludos desde Alicante!
Hi, can you tell me which patch you downloaded and from where? I am facing the same problem with audio after reinstalling a clean version of XP. Thanks in advance!
Thank you, it works now!
Pues mira,los drivers los tienes en la web de sony en support, y los pach para el sonido etc los tienes en el foro,pero si tienes problemas este es mi mail: robsoria@telefonica.net
escribeme y te cuento como lo he hecho.
