Hi all...
I´ve connected my notebook FE21M to tv using S-Video output from notebook to Scart-input on my tv (normal tv, not HDTV). The problem is, when I open Media Center on my notebook, it runs ok. But when I switch the display to tv and run Media Center in full sreen, the tv display turns black with flicker, but I could still hear the sound. I also found out that the flicker-filter in nVidia control panel had somehow changed itself from original setting (127%) to 0%. I´ve changed back this setting to 127% and tried to run Media Center one more time, but I´m still experiencing the same problem.
I´ve also tried to run Media Center in windowed size (meaning: not fullscreen)..and it runs ok on tv screen.So, I cannot run Media Center in fullscreen on my tv.
My graphic card is GeForce Go 7600. Updating the driver didn´t solve my problem....
If someone has solution for this problem, please help me...
i am not sure if this is a solution but close media centre then connect your tv up and then try running media centre and see if that helps the problem. usually if u have motion on the screen (like a playing video for example) and then you connect a tv, only a blank screen will be displayed. give it a try it mite work
i´ve tried your suggestion, but that did not solve the problem. All i get is just a black screen with some flicker on it. Also when i use dual display (both on notebook and tv simultaneously), the display on notebook is also just black, similar to the tv.
Exactly the same problem on my VGN- FE21S - just like yuhaizad posted.
Both black flickering on laptop's LCD, as well as, normal (Standard definition) 16:9 TV screen.
(I also have the dreaded clicking hard drive to cap it all) What is up $ony?
hi... i think i had the same flicker problem up until 5 minutes ago... i just went into the NVIDIA control panel... selected 'change the signal or HD format'
went to 1.TV... 2. s-video 3. UK-Pal... and whe i applied the changed the flicker has completely gone... YESSSS
it's been bothering me for ages... and now crystal clear... hope you can do the same!! 🐵
