I have seen several other threads on reinstalling sony drivers etc to get these keys working, but I cant see the relivent downloads for this model, plus the downloads are managed but the vaio update program.
What can I do to activate these keys ?
Cheers,
Gonul
Hi Gonul
Go Here:http://www.vaio-link.com/downloads/select/select.asp?l=en&category=-1&serie=-1&m=2158#6 and goto the Preinstalled Drivers and Utilities and download the utilities package. that should sort out your problem
Brian
Thanks for that worked first time !
Gonul
The first time my Fn keys and S keys stopped working (Fn+ScrLk still worked) I considered the possible causes and tried to revert them:
* Windows Update had installed July 2006 Windows Security Updates
* Vaio Update had installed VAIO Event Services SOAVES-00824540-UN 11/07/2006 3.66 MB
* Vaio Update had instructed me to manually update BIOS Update R0073N0 PHBSYS-01041217-UN
I reverted the software updates, but not the firmware update in an attempt to get the Fn keys to work, but they had no effect. Messages on his forum indicated that I needed to uninstall and reinstall (not repair) the Vaio Event Service (from utils folder 5) downloaded from vaio-link.com and that worked once, possibly prior to Windows Update, but not again since.
Event Viewer listed an Application event that was caused by Vaio Event Service:
The description for Event ID ( 0 ) in Source ( VAIO Event Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Service stopped.
1 Sony Utilities (Installer folder 1)
2 Sony Shared Library (Installer folder 2)
3 Vaio Event Service (Installer folder 7) - actually folder 5 for SZ1M
