Formatting Without Installing Add On's
Jonny_D_1987
hey guys, just got a lovely vaio yesterday and love it 😄 but i am not happy with all this useless software they have installed 😞 so i am trying to format without installing any of this..... how can i preform a clean install without installing any of this useless software, and only install xp?
thanxs alot guys
jonathan daly
73 REPLIES 73
Thalamus.
Champion
Hi RoksVempire,
did you follow the guide above as usually the Fn keys should work.. :thinking:
What model Vaio do you have.?
RoksVempire
Now works!
I reinstalled Vista with original dvd and I forgot to install vaio utilities...so my last problem is that in my computer I don't see SD icon...I remember that with recovery preinstalled system there were MEMORY STICK + SD...
ripper2712
3 days ago a made a clean format to my vaio VGN-NR31E/S and put the vista again!!!
when i was attempt to install some programs from the recovery disks i realise that the vaio update was missing :slight_frown: now what?
i follow that link http://support.vaio.sony.gr/downloads/updates/updates.asp?site=voe_el_GR_cons bat it has the 3.1 and when i am going to install it a message come and say that message :
 Error Executing the specified Program
C:\Users\RIPPER~1\AppData\Local\temp\pftD2EC.tmp\setup.exe
press ok to continue
then the same one and close
do you know where i found the vaio update 1.0? or another vertion to work and install to my laptop?
Thalamus.
Champion
Hi ripper2712,
welcome to Club VAIO.. :slight_smile:
Did you install the Sony supplied Vista using the recovery disc's or did you use a retail Vista disc.?
