French !!!
XAV38
French !!!
Besoin d'un renseignement sur "SWAP" insuffisant !
Need some suggestions about not enough "swap" !
6 REPLIES 6
DORU
mon ami
je ne parlez francaise...
ok .. you can tray with partition magic 8.... you can just delete swap partition...:smileygrin:
jumpsuit
Bonjour Doru et bienvenue a la Forum.
J'espere que vous passez de bon temps ici!:smileygrin:
Twisted-Rizla
Oui, bienvenue au forum
Mais fassiez attention de Jumpsuit. Il aime de jeunes chevres.
Et cheeseburgers.
rich912
Welcome XAV38.
I cannot explain this in French so here goes in English:
Go to Control Panel and double click on System. In the next window select the Advanced tab, under Performance (visual effects¿) click Settings. In the next window select the Advanced tab and in the Virtual Memory box click Change. You can then alter the paging file (swap file) size.
I hope that all this makes sense.
Go n-éirí an bóthar leat
kee-lo_
I will explain it in French Rich
Allez dans le paneau des controlles
double click dur Systeme
dans le window prochain selectionez le tab avancee
desous Performance (effecs viseaux, clickez sur settings
dans le window prochain clickez sur advancees
La change le memoire virtuele
rich912
Thanks Kee-Lo.
