Function key problem
illudium36
Hello I am new in the club.
Anyway.
I have a problem with my VGN-N11M. I've just formated it (windows xp pro) and all are fine (drivers, apps, games). The only problem is that when I press Fn button and F2 F3 F4 F5 F6 for brightness and volume doesn' t happen anything.
So what I have to do mayby other drivers or enable something or I don't know.
Thank You
rich912
Hi illudium36 and welcome to Club Vaio.
Download the pre-installed utilities for your model from Vaio Link and extract the file. Then install the following in this order:
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Then re-boot.
You may find that you need to repeat this process a couple times before the hotkeys work.
Go n-éirí an bóthar leat
illudium36
1 Sony Utilities
Then re-boot.
Thanks a lot it works fine, i didn't expect this but works.
Thanks again
rich912
Hi illudium36,
You're welcome, good to hear that the problem is no more :slight_smile:
