FW VAIO Blue F12
Rich77
FW VAIO Blue F12
can someone help please,, i have a Vaio FW i pressed F12 with the blue button pressed, it shut down now it wont startup.
Any ideas thanks
Thalamus.
Champion
Hi Rich77,
what happens when you press the power switch.?
Do any of the Vaio's lights come on.?
Are you running on AC or battery power.?
Have you disconnected any externally connected devices.?
This may help...
Unplug the power supply and remove the cable and all connected devices from your Vaio, then remove the battery.
Once done press and hold down power button for a full 30 seconds, then replace the battery and then plug in power cord. Once completed turn the laptop on..
Rich77
I took the battery out re booted windows and its now sorted.
Thalamus.
Champion
:cool: You're welcome.. :slight_smile:
