FZ21M
ehsan777
FZ21M
My serial number is 12 charecter , which is FGR100624031 , I found it in my boot page ( F2 key while starting ) and also backside of my laptop
There is No any 15 digit serial number please help me
Regards
4 REPLIES 4
rich912
Hi ehsan777,
Open Control Panel and then Vaio Control Center. You should find the 15 digit serial number listed under System Information.
Go n-éirí an bóthar leat
ehsan777
Thanks Rich
Unfortunately there is same number FGR100624031 on serial number un system informaion !!!
Really I don't know what should I do !!
rich912
Hi ehsan777,
I have escalated this to Support. Hopefully they will be able to sort this out.
rich912
Hi ehsan777,
Can you please provide photos of the BIOS screen and the underside of the unit that show the serial number as FGR100624031.
You can either post these here or by PM to me if you prefer.
