Game is really slow.
cedricwinters
Hi, today I bougt the game Crysis and when I started to play it, it was very slow.
On the game is put that you need a 2.2 Ghz processor to play the game, but I've a 2.0 Ghz..
Can you help me to solve this problem so I can play the game not so slow.
Thanks, Cedric Winters
tonybeard
Welcome to the club,
Well you can overclock but on a laptop that would be an unwise move in the long term. Best thing to do is to run the game from the hard drive not the optical drive. To do this you need to make an .iso of the game disc and copy the .iso using Power ISO or Daemon Tools to your hard drive. Then go here to game burn world and track down the securom patch at the site to enable you to play the game from your hard drive. if there isn't one then try partition magic and give yourself a seperate bootable partition about 30 gigs in size to install the game on. Finally make sure your system is in tip top condition and defragmented several times before installing the game using tune up utilities
