Graphic
Chrus
Graphic
Is it possible to change the Graphic Card on my PCG-FR215S? I have only a 345IGP and would have have one with 128mb.
Thanks for answer
Chrus
TygerTyger
Golden rule:
You CAN change the graphics card on a desktop.
You CANNOT change the graphics card on a laptop.
saladin
Golden rule:
Any particular reason why not? Is it just that you can't crack the case of your laptop without damaging it, or do they not make new cards to fit inside the case?
kee-lo_
Because it's soldered onto the motherboard.
