Hey all,
Ive been having a problem with my vaio laptop recently as most videos i play seem to skip and freeze (if using vlc media player, windows media ect) and also my cpu usage gets maxed out 100% most of the time, ive looked at what is running in the backgroup and dont have much, done a virus scan and reformated my computer expcect the d drive which was partitioned. The only thing i can think of is the grpahics card is out of date so will try and update it but any other ideas if that deosnt work??
In face i couldnt install the graphics driver which was meant for the Readon igp 345
can anyone tell me where i can get this please, i couldnt find it anywhere
I can't see an available upgraded driver for your Vaio on Vaio-Link.
However, there is a firmware upgrade available for your Optical Drive and for your Audio. There is also a Hotfix for something or other. Have a look at VAIO-LINK
Have you run a spyware scan. If not try SPYBOT SEARCH & DESTROY
A thorough TUNE UP may help!
