HDD Protection under Vista and SZ1
Naujoks
Has anyone figured out if it is possible to install the HDD protection under Vista? How does one actually install it under XP? There's only one .SYS and one .INF file, I think, and no installer. It is probably one of those drivers that might also work under Vista, no?
5 REPLIES 5
Thalamus.
Champion
Hi Naujoks
The info in this thread may help..?
The Vista drivers & utilities can be found here.. :slight_smile:
Naujoks
Hi, thanks for the reply!
The thread you gave me only reports that that guy also hasn't been able to install HDD protection yet. The link for the utilities seems to have everything BUT the HDD protection. Unless I miss something? Vaio SZ1 series here.
Hi Naujoks
kee-lo_
Hi
Right click the INF file and click on Install.
Naujoks
Error message:
"The INF file you selected does not support this method of installation"
Hi
kee-lo_
Probably not compatible with Vista.
