HELP: MY VGC M1 CANT COME ON...ANYONE KNOW HOW TO FIX IT
matrix12
VGC M1
Hi, my VGC M1 has stopped working. I think the power unit is gone as there was a burning smell at the back. Can anyone help me?
Thalamus.
Champion
Hi matrix12,
welcome to Club VAIO.. :slight_smile:
If there is a burning smell I suggest you either contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
Or
See if a local repairer in your area to investigate and quote a cost for repair..
