Help needed Disable screen in bios
Neil_948
Hi i have had my Vaio VGN-FE28B for over 18 months now and the scren has shattered i have been using both tv (via a VGA lead) and a standard monitor which bot work fine with my vaio but i have applied to start working from home and the software that i have been provided with boots up my laptop display and asks for me to select agree of which i can't see because i have no screen how can i disable the screen on my vaio in bios so that it automatically boots the external screen as i have configured windows to do this but the software that i run does not boot into windows first it boots straight from cd which is boot the onboard screen. :slight_frown:
0 REPLIES 0
