hi,
i have a sony vaio 315s. i wanted to know which slot this card would fit in. the top or bottom?
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Product_Id=122968
it is a wireless laptop pc card, which is inserted in a PCMCIA slot.
thanx
devin
Hi again Dev, good to see you back,
I think that can go in either top or bottom, but I would put it on top.
yo man, good to hear from u. i luv this forum, i just didnt like wat sony did to it.
anywayz, y the top? any reason? cos i've put it in the bottom. and when i put it in the top, i have to reinstall the drivers again.
i got a home wireless network now. it was tricky to set up. if sony made a wireless network i would have bought that.
devin:smileygrin:
Same here Dev, love the forum, not what happened to it.
You can put the card in either the top or bottom.
