Help
LouisBibby
Help
Hey I was wondering if anyone knew if it is possible to replace the cover on your laptop as my has a couple of very noticeable scratches on and was wondering if the shell could be replace.
Anyone knows anything your help would be much appreciated. And if anyone knows ideas of where or what could be done if possible.
Thanks a lot Louis.
4 REPLIES 4
LouisBibby
Thanks a lot Louis.
PS... This is a VGN - FZ21S
Thalamus.
Champion
Hi LouisBibby,
you can either contact Sony Vaio Support via phone or E-support, use the following link: Sony Vaio Support
Or
You can try an obtain the parts yourself from a company something like Nexttronics
Or
have you thought of a Lapjacks as a cheaper alternative solution.?
Lapjacks are made from a high quality adhesive vinyl which you apply to the laptop lid to personalise and protect your notebook computer, click HERE to read more..
fubbe
hi, thanks for the lapjack hint. its a nice opportunity to avoid scrachtes. will buy one for my fz21z. besides that, the visual effect is great !
Thalamus.
Champion
:cool: You're welcome fubbe.. :slight_smile:
