How do I safely remove my SD Card
holwalsh
I am trying to find on my task bar the option to safely remove my SD CARD as last time I pushed it out and it corrupted the card.
I can't find the option to safely remove this
please help!
rich912
Hi holwalsh,
Do you not have a Safely Remove Hardware icon in the system tray?
If not have a look at the following link – this is for Vista but may also work with Windows 7.
http://www.vistax64.com/tutorials/173208-safely-remove-hardware-shortcut.html
Rich
Go n-éirí an bóthar leat
