hi,
i have a ar41l, how do i change the graphics memory?? it goes up to 800mb, so how can i change this??
thanks
devin
Hi devin
Your NVidia GPU is adaptive and will therefore increase the allocated video memory depending upon the amount your system requires..
This ensures the GPU is only using enough power as is necessary for the task at hand, which in turn should help prolong the battery life of your Vaio..
so theres no way of actually changing it??
how can i view wat its on?
thanks
dev
