How eliminate hidden partition!!!
nunziovaio
Please, I am newbie.
Hi to everyone.
Can I eliminate, and recovery free space on hard disk, the hidden partition on my VGN-FS315M ?
Thank you very much and scuse me for my english language.
14 REPLIES 14
El_Andaluz
Hi, well i had this problem too...
You can eliminate it, when you re-install de OS. For example, i re-installed the Windows XP Pro. and during the installation you come to the partitions menu, where you can see all the partitions. Now you can delete all and create a new partition to install the OS or you can delete the hidded partition.
If you have any questions, don't hecitate to ask.
Saludos
tdw197
may be a bit of a simple question, but if i follow the instructions on sonys website, will it format the whole drive, and hence lose all progs/data?
Tom
Thalamus.
Champion
Hi to everyone.
Hi nunziovaio,
Welcome to Club Vaio, :slight_smile:
You can delete the recovery partition by simply following these instructions.
If you are going to delete your recovery partition, it may be wise to have at least two sets of System Recovery Discs in case one gets damaged, etc. :wink:
Thalamus.
Champion
Hi Tom
It depends on what instuctions you follow and what type recovery you intend to perform, have a look at this guide for further information, no. 6 may be of interest.
diskostu
hi, without re-install SO you can do that using a program as PARTITION MAGIC with this great program you can delete/create partitions, resize partition ecc.
on my new FE11M i have do this:
- deleted recovery partition
- reduced C space to 25gb
- increased D space to 70gb
All without lost any kind of files.
naturally i did this after created recovery disks
bye:smileyhappy:
tdw197
Ok!
I thought about it, but am always a bit wary of using third party partition manager, but if you say it'll work...............
thanks, tom
kee-lo_
Backup vital data
tdw197
too right...........
just finished recovering my C drive, still runs much faster now
very good advice
Tom
Thalamus.
Champion
Hi Tom,
Did you remove the hidden partition or just complete a system recovery?
