How to clean screen?
maishan
Hiya,
My SZ3 screen has got remarkably grubby the last few days; with fingerprints all over it.
What is the safest and best way to clean it? I don't want to damage any special coating that may be on it!
Thanks!
4 REPLIES 4
olilloyd
Little bit of water ie run your hand under tap then flick sprinkles of water onto your screen.
Then use a cloth (the type you get with a pear of glasses) to clean the screen. Keep cleaning the screen till all the smears have gone!
Best 30 seconds you will spend!
Thalamus.
Champion
Hi Lydecker,
I use nothing more than a dry microfibre cloth to clean my screen and occasionally I might breathe on the screen to remove some spots. These are available from most shops now. :slight_smile:
You may also find this info on Care tips for laptop screens of interest... :slight_smile:
maishan
thanks guys!
Thalamus.
Champion
You're welcome.. :slight_smile:
