how to enable again hibernation mode
gabalint
I would be grateful if someone could give some tips for my problem. I have a TX5MNW vaio with vista. May be a have changed some settings but there is no hibernation option displayed neither in the power management panel nor in the list when I leave the computer with the power buttion in the startup menu. Where can I find within vista the panel where I can chose this option again? Thanks, gabalint.
4 REPLIES 4
drinkfeckarse
do you see the option when you choose start, then the little arrow pointing right next to the pad lock in the lower right corner?
gabalint
Yes, I saw it. My problem is that the hibernation possibility is not there any longer.
gbj
gabalint
I can not find the hibernation option any longer next to the power and unlock button in start menu. Thanks, gbj
Thalamus.
Champion
Hi gabalint,
welcome to Club Vaio.. :slight_smile:
Have you run disc clean up as this can remove the hibernation file and turn off hibernation..
I f so this LINK should provide you with a solution.. :slight_smile:
