How to have the Recovery disk for Netbook PCG-C1MWP ?
jerix7
Hello !
Have damaged my Sony PCG-C1MWP windows xp systeme. So, i have formatted and reinstalled it whith Windows SP3. But, none of the drivers i'have downloaded from Sony want to be installed. I'm so bored and need help.
Thalamus.
Champion
Hi Jerix7,
welcome to the Soy User Community Forum..:smileyhappy:
Did you buy your PCG-C1MWP in Europe because I thought this model was from the US..
If I am correct then your Vaio was supplied with a set of recovery disc's but if you have misplaced them then you may be able to purchase a set of recovery disc's using the information in the following link - How to purchase recovery CD/DVDs for computer products..
Thalamus.
Champion
Hi Jerix7,
jerix7
Thank you Thalamus for your quick reply. Yes my device is an US model.
Since my preview post, i've found on web a good RAR file which contains all of my device drivers. I'm so glad !
But, afert install all of them, my device run too slowly under Windows XP SP3.
It's certainly duet to my configuration Processor (800 MHz) RAM ( 256 Mo) !!!
But i could close that post and try another to fix this problem.
Overall, Great thanks to you for your help ! :wink:
Thalamus.
Champion
You're welcome Jerix7..
