I've just tryed to install xp pro on my aio RC-102
First i have formated and install the xp home version and have configured the raid switched off.
So i've restard with xp pro cd and after click enter and F8 i am now in the window to make partitions and i have just four time
{thre is no disk in this drive.}
Unknow Disk
Unknow Disk
Unknow Disk
Unknow Disk
Please help me.
I think you'll need raid on.
I guessed too, but I did know the system had 2x160GB
Thank you for all your answers ..
Bu as i ve said in my first question, i have formated and re install
with the recovery cd witch one i have burned from (c:)
and used the raid configurator to use the two discs separately (thats what i called raid off) .
Now i have this xp home installed with both hard drives 160Go + 160 Go.
I restart with my xp pro cd and after enter and F8 i have
no disc four time........????????????
That's because RAID is off
Hello.
Thanks a lot but.
I have reinstalled with raid 0 .
After restarting with xp pro cd i have still the same message.
No disk installed. Four time !!!
Does it came from the bios???
Beccause Raid 0 on or Raid off The both discs are recognised as one disk in bios!! And i dont have acces to them.
The problem is I don't think the BIOS will allow you to control the RAID as Sony lock it
Oki.
So it's okay.
I undertand that my first problem was that i had a xp pro version one
witch doesnt contain RAID drivers .(they're present in xp pro that have the service pack 2 integrated).
So i found a folder on my vaio called Driver.
In this folder you will find under raid folder the Raid drivers witch ones have to be copy on a floppy .........you will find the instruction on a text file in the folder DRIVER/RAID....
So i finaly have install my Xp pro.
Thanks to all for your help.
Ps: i have now other troubles but thats another SONY a......story..:-)
That's good news!
