How to transfer the cover album
triki68
Please, could you explain to me how to place the cover album to watch it while hearing the songs?
Thanks.:smileysad:
profile.country.de_DE.title
itbroker
in which software ???
RubenBCN
You have to add the cover to the album folder in Sonic Stage previously. No way if the folder is already in the VP.
MadarbWoT
you can attach the cover by using the command in sonicstage[see sonicstage help for more info],then transfer it and you will see the cover.
if the folder is already on the vp you can put the cover picture in the vaio_photo folder,then view it through the picture viwer in vp menu.when you view the exact pic,you can go to the right menu,there is a little symbol with a disk on it.press that WHILE ONE OF THE SONGS OF THIS ALBUM IS PLAYING[that makes the difference] and that should attach the cover art on the whole album.the next time you play the album it will appear there...
