Hrad Disc Upgrdae for VGN-BX-196P
remitch29
Can I incrrase the Hard Disc size on my Sony Vaio VGN-BX-196P if so how, is there a plug in unit?
rich912
Hi remitch29,
I am almost certain that the BX series has a simple slot in drive that only requires the removal of one screw to extract - no disassembly required. This, I think, is located on the front right hand side when viewed from above.
You should be able to upgrade to 500GB IDE/PATA, but check with the supplier before ordering.
Rich
Go n-éirí an bóthar leat
remitch29
Could you advise on a supplier please Rich
Thanks Rene
rich912
Hi Rene,
I’m afraid I can’t recommend a supplier and a Google suggests that these drives are not as plentiful as they once were. It seems that anything over 120GB is either unavailable or hugely expensive.
Try a search for 2.5” IDE PATA hard drive. Below is a link to one result.
http://www.laptopdrivestore.com/index.asp
Rich
