I've just bought memory. My computer is VAIO VGN-B1VP. I want to install it, but I can't remove. I looked at the manual and web support for memory upgrading. Although I did to instructions in web support, I can't remove keyboard. Is there any secret switch under the about F6 or F7 keys? Please help me.
Have a look around at this link for the correct disassembly to remove the keyboard. Good luck
I tried it, but it hasn't worked. 😞 I think I must go to service 😞
At what part of the procedure are you getting problems?
If at this step
make sure that you insert the screwdriver between the frame and the keyboard surround, not against the key.
Dont forget to remove the screw from underneath the computer.
Page 108 of the user manual
At last, I've installed it by your supports. Thanks a lot.:smileyhappy:
