I need Preinstall Aplications
beniamin_igas
Hallo there!
VGN-N21e/w Win xp sp2,
My Xp don t reconize my monitor it is Default Monitor, and the shortcut from keyboard for brigness and contrast don't work
I need Preinstall Aplications (Vaio recovery tool) if any one of you know an link please answer me!
Viel Dank!
Thalamus.
Champion
Hi beniamin_igas,
The recovery tool is not available for download.. :slight_frown:
Are you sure the recovery partition has been deleted, try pressing F10 repeatedly when starting you vaio, this normally would start the recovery process..
If that does not work then you will have to contact Vaio-Link to purchase a new set of recovery DVD's..:smileysad:
