I Pod Classic
davidjhe
I Pod Classic
I cannot get my VGN-AR31S to work with my I Pod Classic. On dowloading the software, the DVD drive and Windows multimedia stop working.Can only get them back by using "System Restore"Any ideas?David
5 REPLIES 5
profile.country.el_GR.title
petbit
Hi davidjhe ,
welcome to Club Vaio :slight_smile: !!!
Did you create the recovery discs?I think you should do a format. In addition trust your guide-book to find information about how to reinstall the drivers which you have lost...
davidjhe
Yes recovered everything and VAIO working OK.
Is there a conflict with the Apple software and my VAIO and / or VIST.
My previous VAIO PCG-GRT896HP working under XP was fine.
David
Thalamus.
Champion
Hi David,
are you installing the latest version of Itunes.?
davidjhe
Yes, tried I Tunes 8.
Are there any changes that I should make to the default setting?
Regards
David
Thalamus.
Champion
Regards
David
Not that I'm aware of..
The only Vaio AR31S update that I can recall mentioning iTunes is the SATA Driver Update 7.5.0.1017 but that does not match your current problems..
The SATA Driver Update update resolves the following issue:
- Degraded RAID volumes when playing or transcoding video files in Apple iTunes and QuickTime software.
Are you downloading iTunes direct from Apples site.?
