INSTALATION OF XP WINDOWS ON VGN-NR11Z
MILLIONFISH
DOES ANYNBODY KNOWS HOW CAN INSTALL XP WINDOWS?? OR FIND SATA DRIVERS??
5 REPLIES 5
Hi MILLIONFISH and welcome.
Unfortunately there is no easy way to downgrade the NR-Series Vaios to XP at this time. I would use Vista if you can because your Vaio was designed for Vista - I don't think it is possible to get your Vaio working properly with XP at the moment as there is no previous model in the range that was sold with XP.
Sony do not support XP on your Vaio and you may invalidate the warranty. You may be able to find the SATA drivers in C:\Windows\Drivers\SATA or in C:\Drivers\SATA on your Vaio along with the other Vista Drivers but the Utilities are unlikely available for some weeks.
All you can do is find the XP drivers individually from other Vaio models. As far as I know, XP Utilities for the NR-Series will never be released so it will not be possible to use the full functions of the NR-Series with XP. Things like the Fn keys, Power Management, etc may never work.
:slight_frown:
alle treiber für sony vgn-nr11z/S
rich912
Hi schmidt.ralf65,
Try here:
http://www.sony.co.uk/support/en/product/VGN-NR11Z
Rich
Go n-éirí an bóthar leat
thank you
rich912
You're welcome :slight_smile:
