install last graphic driver
MouhcineFD
I have sony vaio z2 model svz1311c5e windows 7
recently i get some problem with some application because of the graphic driver
i have intel hd graphic 4000 and the the driver released in 2012
when i wnat to install the last version from intel website i get this msg i ignore it and i install the last version
all problem with application have been fixed
But a new problem emerged with the new driver. the brightness doesnt change slowly
Example: if the brightness is 10% and i changed it to 30% is changed from 10 to 30 directly not step by step and these It hurts my eyes .
with the old driver , the changed applied slowly 10 11 12 13 to 30
Tags (5)
4 REPLIES 4
cass_n
Community Team
Hi @MouhcineFD,
You will need to install the latest driver from the Sony support site, here.
Hope this helps.
Cheers,
Cass
MouhcineFD
Yes but the last vesrion in sony support site it's so old from 2012
cass_n
Community Team
You will still need to install the Sony driver to resolve the issue (even if it is from 2012) - so I recommend you try this.
Thanks,
Cass
MouhcineFD
but they are many application can't work with graphic drivers from 2012
like google map in satellite view
