Installing a 512 GB Crucial M4 SSD in a VAIO VPCSE190X
payared
Hello,
I ordered the following machine for my daughter and I didn't choose an SSD during my order there was on offer some unusual dual SSD with RAID 0 without any explanation as to the purpose and advantages of such a setup. So I went ahead with a hard drive.
Product:
US-VPCSE190X-LBOM
Component:
Internal lithium polymer battery (4400mAh)
Component:
Fresh Start
Component:
Blu-ray Disc™ player
Component:
Intel® Core™ i7-2640M processor (2.80GHz / 3.50GHz with Turbo Boost)
Component:
4GB (4GB fixed onboard + 1 open SDRAM slot) DDR3-SDRAM-1333
Component:
Genuine Windows® 7 Professional 64-bit
Component:
AMD Radeon™ HD 6630M (1GB) hybrid graphics with Intel® Wireless Display technology
Component:
15.5" LED backlit Full HD display (1920 x 1080)
Component:
500GB (7200rpm) hard drive
Description:
15.5" S Series Customizable Laptop
But I've now bought a Crucial M4 512 GB SSD (Crucial 512 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s CT512M4SSD2) which I'd like to install in her latop instead of the hard drive, using the Apricorn SATA Wire Notebook Hard Drive Upgrade Kit ASW-USB-25.
Can someone please tell me:
1) Whether this will work. If it doesn't then I can return the SSD without any problem
2) Whether there are issues I should pay attention to (BIOS? SATA? IDE? Drivers?) - All mysterious to me.
3) What I should do in sequence. Perhaps disable defragmentation before cloning the drive?
Thanks.
P
profile.country.pt_PT.title
platao
Yes it works flawless no problems with Bios! I haven't clone it I've just put inside and reinstall everything with the help of the "Asssist "button and then after this restore the old stuff
Best regards
payared
Thank you. What is the "assist" button?
