Is my Sony Vaio VGN-FE11S laptop Windows Vista compatible?
timauluck
Dear Sony Forum Users,
Your regards,
Timbuctoo
4 REPLIES 4
Thalamus.
Champion
Hi Timbuctoo
Have you downloaded and run the Windows Vista Upgrade Advisor. If not use this link: Windows Vista Upgrade Advisor
timauluck
Dear Thalamus,
I have downloaded and ran the Windows Vista Upgrade Advisor from the Microsoft website, but there were a few hardware and software issues that were stated in the log after the system scan was performed.
Your regards,
Timbuctoo
MT-FE11S
Dear Timbuctoo,
Your FE11S is probably able to run in Windows Vista.
Last time I installed a clean Vista Ultimate on my FE11S and it works fine in some parts. Only the headphone and all wireless functions will be not working properly.
Please note that I am keeping also the original XP on my FE11S beside the Vista, so I have dual boot. But someone suggest me that I should not replace the original OS (XP in this case), coz I will not be able to recover it from the hidden partition again in the future.
timauluck
Dear MT-FE11S,
Thank you for your response to my enquiry, I will keep your advice in mind before upgrading to Windows Vista.
Many thanks,
Timbuctoo
