Is there a maximum size hard drive (Gb's) that can be fitted to a VGN-AR31E?
scholar7
profile.country.ES.title
franktfe
Hello scholar7.
Your laptop have no limit for hdd capacity. But you only have to be careful with just one thing.
Your unit has two hard drives, you need to be sure the unit you are going to replace is the slave (secondary) hdd not the master one.
Regards.
p.s excuse my english.
Saludos.
franktfe
Hello scholar7.
Regards.
Saludos.
scholar7
Thanks for your reply franktfe,
I will look into your suggestion that there are 2 hard drives, since I was under the impression that there is just 1 physical hard drive which is split into 2 vitrual (or logical) ones by partitioning the disk.
Regards
Scholar7
