Is Vaio Care liying to me?
AFR0N1
 I recently got a new battery for my vaio because the old one has died.
The new battery is working great so far, it will charge to 100% and it will hold its charge for a good amount of time.
I don't see any issue with the battery, but vaio care thinks otherwise.
When I go into vaio care, it still notifies me that the battery health is critical.
So is my battery good or not? Is Vaio Care liying to me or hasn't realized that this is a new battery?
How do I fix this?
AFR0N1
The battery was a fake! This is the cause for the problems!
AFR0N1
