ISO image Burning
S5VPspecial
ISO image Burning
sometimes when i try to burn an iso image file using NERO 7, it goes through the process but there is nothing on the disc when completed. This has happened a few times. Is this just a bad file or is there any extra settings I need to change or software to download.
jumpsuit
Nero 7 has had pretty bad reports from all directions, but that could be due to conflicts with other burning progs.
You could always try installing Nero 6 to see if it works.
