itunes keeps getting wiped
alib81
My computer keeps wiping itunes off does anyone know how to fix this problem? I'ts becoming a real pain.
Thalamus.
Champion
Hi alib81,
welcome to Questions & Answers..
Also check if there are any VAIO Entertainment Platform Updates available for your Vaio on the Vaio Support update site, as they may help with the iTunes problem..
Click the following link to access the - Vaio Support site
It is possible that the iTunes default Library has the same folder name as one of the Vaio Media default Libraries and they are wiping each other's content.
To avoid a conflict, choose a new name for your iTunes default library and set it as default by holding Shift when you open iTunes.  Have a look here: -
http://support.apple.com/kb/HT1589
:wink:
Thalamus.
Champion
Hi alib81,
