What does the jacket function on the VAIO do?
And:
How do you use it?
Dont know, I don't have a VP
may be it's to shutting the buttons.
may be you find the answer at the manual?:smileygrin:
manual
From a google:
'The LCD screen can display an album jacket while playing music. It also serves as a photo viewer by displaying and managing image files. The VAIO pocket is equipped with a touch pad style interface called G-sense, which operates in conjunction with the LCD screen.'
How you use it, I haven't a clue as I don't have a Vaio Pocket.
I hope that this helps.
hi
you can use the jacket function to see all the album covers attached to the music that you transfered through sonicstage.if you click on one of the pics you get transfered to its album.
that's all it does in mine.
plus,the covers are in small size and when you touch the g-sense button that marks a pic,it gets resized but again not very big.
it doesn't work, i selected the album cover with sonic stage and transferred but it didn't show up in the jacket menu.
am i doing something wrong?
Hi all
Okay first things first, sony rules. now that we are all on the same page i may be able to help.
when you record an album with sonicstage you can add the cover art to it by simply dragging the bitmap or jpeg onto the album. now once you have done this the picture will be displayed on sonicstage. now after this is done you can transfer the album (with the cover art now attatched) and it will show up in the jacket.
hope this helps
i use musicmatch jukebox to copy mp3 on my hd from cds.it allows the user to include the cover of the tracks cd in the very mp3 file,by attaching it to the file[you can see that by the file size-it increases]
when i transfer one of the albums that have the cover attached,the cover is automatically found in the jacket menu.
dont know if that helped it just simple when you have done it...
Hi.. mine works fine with cover art...
right click on ambum, go to properties and click on cover art.. then add your jpg... works for me....
Ahh thanks everyone it workes now! :smileygrin:
