my x key was sticking, hoving done a little research it was suggested it may have some dust under the key, so I tried to lift it a little to blow out any dust and the top popped off....do you think I cAN replace it....no, is there any info anywhere how to replace it, it just wont pop back on..
Hi Sandy1,
what model Vaio do you have, as we may have a key replacement guide for your model..
vgn A617B
Hi Sandy1,
I've sent you the Key replacement guide in a Private Message, click HERE to view your messages ..
I hope the guide helps..
Thank you so much, just what I was looking for, job done....
You're welcome..
