Keyboard needed for Sony Vaio PCG-FR285M asap....
ash213
I own a sony vaio pcg-fr285m laptop.
I have accidently broken the keyboard by spilling a can of redbull on it and hardly any keys work now !
Sony quoted me about £85 to fix it, but thats too high for me.
I found a shop online that said £130, and some one on ebay has one for £125 but still all too high.
My question is, is there anywhere people know that i can get it cheap ? second hand cheap ? if possible as i need to fix it asap.
Thanks for your help in advance, by the way im from England, UK.
rich912
Hi ash213 and welcome.
If that is a firm quotation I would accept it without hesitation - you will not find a replacement keyboard any cheaper than that, unless you hit lucky on eBay.
Go n-éirí an bóthar leat
ash213
That was about september last year.
Iv been using a usb keyboard since which is annoying.
85 is quite high tho. they would also have to take it away for a month or so !! cant have that.
Does anyone know the serial of keyboard im looking for as theres usually loads on ebay but just have a serial code so i need to work out if they can fit my fr285m model.
rich912
I THINK the part number you need is 1-478-086-31, but check this out before ordering.
Nexttronics may provide futher information if you email them (your model is not listed).
