I've got a PCG-FR215H and looks there is a problem at the keyboard. Not serious but like to remove if for a short time. If someone could tell me (prefering step by step) it'd be appreciated
cheers joe
http://condrix.fw.hu
It was a simple procedure on earlier models Joe, and I have a feeling that Sony have cottoned on to this to ensure that you have to use their support.
Try posting your query at Vaio Village
Thanks Richard,
I had to change my 40GB HD to a 60GB, there wasn't any problem or trick but now I want to change the DVD writer and I just can't figure how could I remove the old one.
Anyway: I'll remove all visible screws bolts whatever and will see. At least I hope
Good luck
Good luck
Congratulations, glad it all went well
Lol I didn't mentioned that a week ago my original 40GB hard drive has been replaced by a new 60GB one and I thought I have to remove the keyboard to change the DVD writer as well, (because that Thosiba thingy wasn't perfect from the very start so I bought a new Panasonic DVD-RAM):smileygrin:
DVD-RAM? Thought they were knocking that on the head?
I think they are, DVD-RAM used to be the most pospular type of disk, now it looks like it will be made extinct.
Hehe, it looks a bit confusing, sorry I wrote it w/o thinking about it, anyway Nero Info says: Matshita DVD-RAM recorder
But we know DVD-RAM just a media or so... :smileygrin:
