LAPTOP SAYS "LOCKING" THEN SHUTS DOWN.
profile.country.IE.title
berhenne52
My laptop battery has died. Doesn't charge anymore. Now when i turn it on, a message saying "locking" comes up, then laptop shuts down. Is the battery causing this to happen, because when i remove the battery and just work from the mains leads, everything works fine, and no message comes up? Any help would be appreciated. Cheers.
Peter_S.
Genius
Hi berhenne52,
Yes, this is a result of the defective battery.
Peter
berhenne52
Thanks for the reply. I Suspected this was the case. Thanks for your help. Cheers.
