My screen is turning down the brightness every minute, although I'm on AC.
I have to push Fn+F6 all the time.
I have changed the preferences in the Vaio Power Management but that doesn't help.
Anybody know what to do???
This Vaio notebook seem to be my worst buy ever...:smileycry:
Some VAIOs have a sensor which turns down the brightness depending on the enviorment you're in
I have the same problem. Well, nice if there is a Sensor, can I somehow deactive it or change its properties?
If nothing helps use a black tape on the sensor.
