Matshita DVD-RAM UJ-850S error : " Sense: 03 ASC: 73 ASCQ: 03 (Command 2A) "
code159
I tried to burn a CD and I always get an error.
Does anyone know what this is?
Px.dll: 3.4.36.500
PxAFS.DLL: 3.4.36.500
pxdrv.dll: 1.2.1.0
PxMas.dll: 3.4.36.500
PxSFS.DLL: 3.4.36.500
PxWave.dll: 3.4.36.500
pxwma.dll: 1.0.0.3
I'm using a VAIO VGN-FE41S (vista) which has a Matshita DVD-RAM UJ-850S ATA device.
My VAIO Update is always running, so I should be up to date.
Thanks for helping me.
9 REPLIES 9
Thalamus.
Champion
Hi code159,
welcome to Club VAIO.. :slight_smile:
From what info I have been able to find the Sense: 03 ASC: 73 ASCQ: 03 = Power Calibration Area Error..
Have you tried using different make of media.?
code159
Hi Thalamus,
thanks for answering and helping.
But unfortunately I'm not sure I understand what you mean :smileygrin:
What do you mean with " different make of media." ?
Do you know what that " Power Calibration Area Error " means ?
I was trying to burn some pictures on a CD.
After loosing 4 CDs I quit trying.
Thanks again.
Thalamus.
Champion
Try using a different brand of CD, for example if you are using Memorex try a Verbatim CD..
code159
I did, I used one EMTEC, two different PHILIPS and the forth I don't remember, I already trow it away.
But I almost always use emtec or philips, and it always worked fine.
I installed McAfee internet security suite yesterday, before I was using the free Avast, and I started to have some doubts, but no viruses found.
I've looked around and tried to understand myself...
Someone, somewhere, was saying to uninstall the driver, to reboot, and the driver would install itself again automatically at reboot.
Is this true, and is it safe to do this?
Do you think it's worth trying?
Thalamus.
Champion
Hi code159,
try this..
Click start ant type Device manager into the search box
Click on device manager from the list..
1)In device manager expand the IDE ATA/ATAPI controllers and make sure that they all are using DMA mode..
2)Then check DVD/CD-Rom drives, are there any warning icons, if what error code is displayed.?
3)If there is not an error code try removing your DVD from device manager and reboot your Vaio and allow the DVD drive drivers to re-install..
code159
Hi Thalamus,
I've checked it out :
1. All the IDE ATA/ATAPI devices where there is the possibility to enable (or disable) the DMA was enabled.
2. No warnings or error codes to be found... But something didn't look right :
In the first tab of the DVD device, the location is " Locatie 0 (Channel 0, Target 0, Lun 0) "
I have no clue what this means, but all set at zero doesn't look right. Is it? :thinking:
3. I'll try it after you told me whether or not that location thing is o.k.
In case I have to try your option number 3. , how do I do that?
Is it simply in the device manager where I select the matshita DVD and then click " undo installation " ? And then reboot and accept?
Thx again for your help.
Thalamus.
Champion
That's ok..
Right click on your CD/DVD drive and select uninstall..
Restart your Vaio and the CD/DVD drive should re-install
code159
I uninstalled the drive and reboot my PC, the drive has been reinstalled, but unfortunately the problem persists.
What else can I try?
Thx.
code159
Thalamus? Anybody?
I really would like it to work, it's been months now.
Thx in advance.
