Memory capacity on Vaio VPCEB2Z1E
Ronin_pH
Hello Community!
I have recently got my hands on a Sony Vaio VPCEB2Z1E laptop, and I would like to put some more memory in it. Therefore, I'm wondering how much it can handle. It has 4GB today, and I would like to put 16GB in it. Anyone know?
I have scoured the interwebs, and only managed to find a User Manual for this model. Otherwise, nothing. Nothing on Sony's Esupport pages, nor anywhere else.
Thanks for your time and help!
Best regards
Tags (3)
rich912
Hi @Ronin_pH
According to CRUCIAL the maximum memory supported (not to exceed manufacturer supported memory) is 8GB. Whether it will recognize more than this on a 64-bit OS is only open to experimentation....
Rich
Go n-éirí an bóthar leat
Ronin_pH
Thank you for the reply! Same as I managed to find in a corner of the internet.
It looks like I just have to decide whether to wing it on 16GB or to play it safe on 8GB....
rich912
Hi @Ronin_pH,
Personally, as Crucial offer a 2x4GB kit as at resonable price, I would stick at that....up to you.
Rich
