Does anyone know anything about these memory modules ?
If I buy a 512MB memory module for my laptop will it work faster & is it compatible & easy to fit ?
My Vaio is a VGN-S4HP model, just over a year old.
Thanks.
Hi spookie,
Your model comes with standard memory of 512 MB and is upgradeable to 2048 MB. The normal configuration is one 512 MB chip in slot 1 with slot 2 empty but check that slot 2 is empty before ordering a single module just in case 2 x 256 MB chips have been installed.
One memory slot is in a compartment on the underside of the notebook and the other is under the keyboard. Have a look here for details on fitting/replacing memory.
I suggest that you speak to Crucial.com re compatible memory. You will not find your model listed but I am sure that they will be able to supply the correct modules for your model and they guarantee compatibility.
Upgrading to 1024 MB will certainly give improved performance with some applications.
Thanks for the info Rich912, I'll check it out before I buy it.
