Memory Settings folowing upgrade?
Phil772
I have increased my memory from 512 to 1024 on the A297XP with XP Pro. I was wondering if I should change memory settings on the system to make the most of the upgrade or leave it as it is? :thinking:
Any suggestions welcome
Phil :cool:
robpaxton
You should just leave it as it is. You could try changing Windows virtual memory settings if you like but any changes will only give marginal, if any, improvement.
