Memory Stick and SD/MMC icons missing
awillson
Upon doing a install of my own Windows, both memory stick and SD/MMC icons are missing within 'my computer'. They simply show up as a white 'paper' like icon.
I have read this before in this forum, i tried searching but nothing worked for me. TBH when i search anything, it doesent work.
Does any one have any idea where and how i can get these icons back.
Cheers. :smileygrin:
5 REPLIES 5
olilloyd
Its somewhere on the sony website because i got it yesterday! Will have a look and let you know if i can find it again!
Thalamus.
Champion
Hi awillson
If you just installed Windows XP, have a look at Rich's solution in this thread.. :slight_smile:
Unfortunately the Search function is not working properly, hopefully it will be fixed soon.. :pray:
olilloyd
Got it for you mate:
http://support.vaio.sony.ie/downloads/os/vista/upgrade.html
You will see "MemoryStick Icon Registry patch" on the left and then click on any link (they all use the same version of the patch) for the download.
awillson
cheers guys,
Thalamus > thats the link i was looking for :smileygrin:
olilloyd > cheers, i will keep that link for reference :cool:
Thalamus.
Champion
:cool: You're welcome awilson, glad I could help.. :slight_smile:
