Memory Stick cant be recongnized
HassanE
Hello to all, this is really urgent.
Today i got a sony cybershot DSC-H9, with a Sony memory stick Pro Duo (2 Gb), and i have a Vaio VGN-FE31B with Windows Vista ultimate.
The problem is that windows cannot recognize my memory stick, and i couldnt find any driver fot it on the internet.
When i insert the memory stick in its slot, nothin happens at all!
Please i need your help, this is really important.
Thanks to all in advance.
Hi HassanE,
You need to install the "Texas Instruments PCIxx12 Integrated FlashMedia Controller"
VGN-FE41Z Downloads - Vista
To obtain this driver, download the 'Original Drivers Package' for the FE41Z which was sold with Vista installed. Extract the files to a temporary file (Say C:\Drivers).
Go to Device Manager - do you have an unknown Mass Storage Device with a warning? If yes, right-click on it and choose 'Update Driver'. Point the installer manually to C:\Drivers\Memory Card\ti21Sony.INF
:wink:
HassanE
Whoaaaaaa man !!
It really worked ! it really worked ! haha !
I might sound stupid, but you just can't believe how much i used google today ! haha !
You are a life savior, Thank you so much !!
